1965 Big block clutch fork rod - NCRS Discussion Boards
  • Brenton M.
    • May 31, 2006
    • 66
    Can someone tell me if there is a defference in the clutch fork rod in a 65 small block car in one from a 65 big block.
  • Steven S.
    • August 29, 2007
    • 571
    Re: 1965 Big block clutch fork rod
    Yes, the BB rod is roughly 1.5" shorter.
    Steve
    • Wayne M.
      • March 1, 1980
      • 6414
      also, don't forget that in addition to Steve's mention of the clutch fork rod; the [lever / bellcrank / Z-bar] is different, and the clutch pedal rod to Z-bar is unique to L78. It's all part of the BB package.
        Brenton -
        Yes - the whole system is different between '65 small and big-blocks. Small-block uses an 18" pedal pushrod, a cross-shaft with 135* arm separation, and a 10-9/16"-long fork pushrod.
        Big-blocks use a 19-1/4" pedal pushrod, a cross-shaft with 155* arm separation, and an 8-9/16"-long fork pushrod.
