Thought I would ask for help before I destroy something
Can someone provide me the length for the four bolts used to anchor the dog bone shaped plate which holds the compressed leaf spring to the differential? (GM 3833486). Two of the bolts are a good 1/8" from seating and very difficult to turn at this point. The bolts I am using are aftermarket and they were unmarked in my parts bin-I may not be using the correct ones.
My leaf is installed on both ends so it is compressed prior to torquing these four bolts, I also followed the advice on other threads, and shaved down the height of the aftermarket center bolt to fit in the pocket under the differential.
Thanks for your help,
Pat
Can someone provide me the length for the four bolts used to anchor the dog bone shaped plate which holds the compressed leaf spring to the differential? (GM 3833486). Two of the bolts are a good 1/8" from seating and very difficult to turn at this point. The bolts I am using are aftermarket and they were unmarked in my parts bin-I may not be using the correct ones. My leaf is installed on both ends so it is compressed prior to torquing these four bolts, I also followed the advice on other threads, and shaved down the height of the aftermarket center bolt to fit in the pocket under the differential.
Pat
