Were the carb setups installed at St. Louis? If so, how were the engine run tests conducted (natural gas) before shipment at Tonawanda? Especially the tri-power cars. I saw a similar question on the other forum.
Carburator Installation Tonawanda/St. Louis
Re: Carburator Installation Tonawanda/St. Louis
Yes they were. Natural gas used to test fire engines at the engine plants.
Larry- Top
John Hinckley has posted a great photo of the dry fire rig they used at the plant. I can't find it. I know it's here somewhere !! Maybe John will chime in and post it.
Tom Hendricks
Proud Member NCRS #23758
NCM Founding Member # 1143
Specialist for 27 years at BUDS Chevrolet.- Top
The purpose of a carburetor is to meter and atomize LIQUID gasoline into a fine mist, mix it with air into the proper fuel/air ratio, then meter the mixture into the intake manifold as required.
Since natural gas is already in a gaseous state, much of the complication of the carburetor is un-necessary; the configuration of the fuel system needed for hot run at the factory likely had little resemblance to a carburetor.- Top
- Top
Here's a page from the Restorer, Vol.18, no. 3. Article written by Terry McManmon about the Tonawanda Mark IV assembly line. This page covers hot test.
I was there when they were doing tri-powers. but don't remember any details of the adapter for that manifold.
- Top
New question, Was the tri power manifold add at st. louis also?- Top
The 1969 AIM in UPC L71 sheet A1 shows installation of the 3x2 carb and choke. So I would say they were installed at St. Louis.Larry
2002 Z51 Convertible
1969 L46 Convertible- Top
- Top
