Small skip - NCRS Discussion Boards
Small skip
  • Timothy B.
    • April 30, 1983
    • 5177
    Re: Small skip
    Lawrence,
    Has this skip just started or did it begin with the overhaul of the engine? I agree that the reproduction wires may be the problem, that's where I would look. If the skip was carburetor related the problem would have been there from the beginning.
    Also, check the routing of the wires as #8 and #4 and #5 and #7 should not be next to each other in the rubber grommets, in fact I think they are on the ends of the grommets. If you search the archives there is info on the ohm ratings for the different length plug wires that may help.
    • Lawrence S.
      • April 1, 1993
      • 775
      Re: Small skip
      Car runs fine now. I played with the timing and installed the correct vacuum canister.
      Car runs fine down low Duke...chugs up my driveway at 500 rpm if I let it. 3.70 gear must help.
      Thanks to all...I appreciate it.
