Re: Leaky Donut Exhaust Gaskets*#*##*
My observation is that these aftermarket exhaust systems don't use the donut sleeve, this sleeve is made into the reproduction header exhaust pipe.
On original GM systems the sleeve centers the donut inside the exhaust manifold as well as the header pipe and keeps the donut from being cocked somwhat. It could be possible this is the reason the packings blow out.
This sleeve is important on the heat riser side because if the donut and header pipe don't stay centered with the exhaust manifold the heat riser valve will not open/close freely.
