Fuel Question For Duke - NCRS Discussion Boards
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Fuel Question For Duke
    Originally posted by Domenic Tallarita (51287)
    Clem,
    Funny you say that because I turned my distributor every change of fuel.
    I tightened my distributor just enough that it would turn with grease on the gasket.
    I would drive a few blocks and listen for the ping or lack of then adjust the distributor a few % .
    There were differences in the 92 octane from station to station and I found that 92 at one station was not the same at another and again I would pop the hood and reach out from the door and turn the distributor.
    As you may remember, the old timers would say to forget using a timing light, just get it to ping under load, then retard it enough to eliminate the ping and you are optimum.
    DOM
    back in the day when i did not run a vacuum advance on my HP street engines i built a threaded device that replaced the vacuum advance that had a thumb wheel i could turn so many turns and i knew how many degrees i advanced or retarded the timing. came in handy for street racing when you opened the covers on the headers for a little street race to help make the car payments. also had a switch to bypass the ignition resistor.
