My latches and release handle are painted body color is this correct?if not are the plated? Thanks, Ed
63 Convertible Latchs And Release Handle Question
Re: 63 Convertible Latchs And Release Handle Question
Stu, I Should have specified exactly what pieces I was talking about, I was referring to the under side of the deck lid that releases it to open, The handle and latch mechanisms are painted on mine. Was this a done from the factory or when someone painted the car previous.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Ed - maybe a little confusing Ref Sec 1.00 sheet C7.00 (that' the 64 AIM)
latches- the small latch (lock asm) on the front side of deck when closed one can not see them. they hit a chrome section of metal to force them closed. #4 pn 3797331 On 64 they are painted.
release handle- at front center underside (control asm), used to open the deck, #13 pn 3823148 On 64 they are painted.
NOW you will need to confirm what was done for 63, early late or ....???
You 63 guys have things tougher then most C2.- Top
The lever, cables and latches on the underside of rear deck lid were in place when the car was painted at the factory.
Ken- Top
I agree with that Ken at least for the later cars, but for early ones, they definitely were not painted. I have worked on several. At least into the 360 ish range there was no paint on the under mechanisms. I dont know when the change in proceedure occured.
- Top
Great info guys, I can now confirm that my March car has painted hardware, my car has had a couple of re-paints so I just wanted to be sure that this was correct.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Wayne, I just looked at a 63 vin. no. 2127 and its around a Oct. built car and it has unpainted latches and cables and release handle. Wow- learned another anomaly about the 63 cars. so many of them.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
