1960 extra holes in the firewall? - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2580
    I have my 60 body up on its side and have been cleaning the bottom and firewall areas, and patching all the extra holes that got drilled over the past 50 years.
    Can someone with a 60, or even maybe a 58 or 59 take a look and let me know if the holes I have pictured are not supposed to be there, or if so, what they are for?
    In picture one, I have labeled the holes that I can identify and there are three holes with a question mark that I can not identify. Also, I scanned a page from the AIM and it only shows the holes that I have been able to identify.
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Joe M.
    • April 30, 1990
    • 1338
    Re: 1960 extra holes in the firewall?
    The holes in question on my 1960 are plugged with grommets; pushed in from the interior of the car.
    • Joe M.
      • April 30, 1990
      • 1338
      Upon further inspection, the two grommets are holding up part of the firewall insulation.
      • Donald H.
        • November 2, 2009
        • 2580
        Never thought of that. I didn't know it when up under this area. I actually have a new set of firewall insulation that I order just to make sure I had all the holes aligned. I'll check it out. I assume it is the two outermost holes where I have the question marks.
        I'm not sure what the third extra hole is, the one that had a bolt screwed into it now. Do you also have that hole?
        Don
        Don Harris
        • Joe M.
          • April 30, 1990
          • 1338
          I just took my car to the shop for repair; sorry I can't provide you with an answer on that.
