Re: 1969 Tri-Power Carb CFM Ratings?
[quote=Duke Williams (22045);553462]Most V-8 manifold designs are compromised to one degree or another. The ideal set up would be identical inlet runner geometry on each cylinder (although Can-Am engines used two different length inlet trumpets, which helped smooth out the torque curve, but other than trumpet length, the runners were pretty much identical.)
i under stand the different lengths were done because 2 ports on each head turn into the center of the chamber and 2 ports turn into the chamber wall which hurt the flow in those 2 cylinders. that may have smoothed out the torque curve.
i often wondered why GM did the computer controlled carbs and then the throttle bodies before going to true fuel injection. they must not have had the software under patent till later.
