Greetings,
I've been experiencing a problem with a leaky/misaligned fuel line on my '66 300 hp 327. The car has the original intake, the original 4657 fuel pump and a 3367 Holley. I purchased a new chrome fuel line (from the pump to the carb) from CC and in attempting to install it could not get the flare nut fittings to thread simultaneously into both the fuel pump fitting and the the carb fitting.
The bends on the two ends of this line did not/do not seem to line up with the respective pump and carb fittings. So...........I purchased the same fuel line (300 hp) from Paragon and it appears to be even more of a problem--the Paragon line seems a greater distance between the two ends. Hence I did not try and fit the Paragon line but instead attempted to bend the CC line in a tighter radius on the pump end (to improve alignment).
This approach (although done with a fair amount of apprehension on my part) enabled me to get the flare nuts threaded on both ends, although with some interference from the thermostat housing. However I now have a leak at the carb end. I personally am not adverse to using teflon tape, however some on this forum have stated that it shouldn't be needed and I was already experiencing substantial difficulty in just getting the ends to line up sufficiently to thread the flare fittings in (teflon tape works best when the fittings are properly lined up and the two thread easily into each other). Oh......the thermostat housing is a 660 aluminum item.
Anyone else run into this? Thanks.
Bill
Bill
