Hello,
I have my '65 in the repair shop. As it turned out the brake line needs to be replaced - it ripped open in the shop while bleeding the system.
I know that the line can't be installed factory like without lifting the body. The shop owner told me he must realign the line and, in order to get the line fixed he needs to drill holes in the frame for the clips. Here in Germany the car is examined every 2 years if it's compliant with technical guidelines - no cable straps are allowed and the repair has to be acceptable for the inspector.
If I had experience, time, space and help maybe I could figure out a way to install it as closely to original as possible (except the rear kick member). But that is not the case.
I'd like to ask if you can give me some tips (that I can forward to the shop) what can be done to be as original as possible when considering the crucial spots at the frame in this context. Sorry for not being more specific - the car is away so I can't have look and my knowledge is more than limited in this area.
Regards
Oliver
Regards
Oliver
