69 headlight support rod finish - NCRS Discussion Boards
  • Brad S.
    • July 31, 2005
    • 227
    What is the finish on the rods that go from the headlight support to the support between the headlights and the hood opening? Are thy black paint, black phosphate or natural? Thanks for any help
  • Grant W.
    • December 1, 1987
    • 407
    Re: 69 headlight support rod finish
    Hi Brad
    If these are the 2 rods one on each side making a V shaped form bolted to the headlight support. Then the rods are semi gloss black. Same color as the headlight support. There should be some body color over spray on them.
    Hope this helps. Grant
