57 splash shields??? - NCRS Discussion Boards
  • Ken G.
    • December 11, 2008
    • 98
    [IMG][/IMG]I received 4 pieces that the seller claimed were splash shields for a 57, the AIM manual is not much help and for the life of me, I cannot sort out how and where they attach. I have replaced the entire front clip so there are no holes to give me any hints. Can anyone help with diagrams or photos? Are these even correct pieces?
    Ken
    [IMG][IMG][IMG][/IMG][/IMG][/IMG]
  • Adam S.
    • July 30, 2008
    • 167
    Re: 57 splash shields???
    Hi Ken, here is a picture of the drivers side looking down in the area by the brake cylinder on a photo I saved from someones original 57 corvette, hope this helps, AIMS manual should help as well, see attached pict. & good luck, Adam.
    • Adam S.
      • July 30, 2008
      • 167
      Hi Ken, here is a view from bottom, as you can see , there is one bolt that attaches to frame as well, you should have that one on your frame for starting point & the three holes on drivers side will attach to edge of large plate to inner fender wall lower edge, good luck , someone may chime in to help as well.....
      • Susan M.
        • January 10, 2011
        • 63
        Hi Ken, I am restoring a 57 now and I had to replace 1 spash shield. Your set looks ok; If you go to Corvette Central and search splash sheilds (item 571071) there is a photo of the pieces. They look like yours. Let me know if you need additional input or if Adam's info takes care of it. Regards, Susan
        • Ken G.
          • December 11, 2008
          • 98
          Thanks! I will try arranging the pieces of the puzzle and see if it makes sense.
          Ken
