The '56-'57 JG says the engine block freeze plugs were plain, no size or logos were stamped into the bottom of the cup. Anyone know of a source for these? Thanks.
SB Freeze Plugs-source
Rob,
You can get correct, no-logo freeze plug in brass from:
Cresap Automotive Machine
631 N Mechanic St
Cumberland, MD 21502
(800) 850-8794
The cost is $2.95 per plug + S&H; about $34 total for a set of eight.
Gary- Top
Re: SB Freeze Plugs-source
Rod,
If the original freeze-plugs for '56-'57 were steel instead of brass, LIC has them, no size or logo stamps (LIC p/n 21-41A).- Top
SB Freeze Plugs-source; brass vs. steel
Scott,
Originals were undoubtedly steel, not brass, but presuming the block and freeze plugs are to be painted, why not use brass and never, ever worry about one rusting though, as steel will eventually do? That's the plan for my '66 anyway.
Gary- Top
Hi Gary,
That is an excellent point. I thought I remembered reading in the archives that the judges check for steel or brass, but I'm not sure now. I just checked the "Mechanical" judging sheet, and I didn't see anything for freeze plugs.- Top
Put a little body filler in the stamping before you paint it then. No big deal and it can't be detected.
Jim- Top
I've seen steel ones fail in less than 10 yrs in cars that sit around a lot. I think brass is an obvious choice given the trouble involved in changing leaky ones.- Top
