�67 300HP Distributor Question? - NCRS Discussion Boards
  • Michael M.
    • February 7, 2011
    • 186
    Initial advance is set at 6 degrees, giving 22 degrees of advance (initial plus centrifugal). I have experimented with different springs but only see variation in the RPM where full advance is achieved. The weights appear to be original (aged the same as top of mainshaft) and there is no bushing installed to limit centrifugal advance. I have installed a new vacuum advance canister (Napa ECH VC-1802, stamped B22), which gives a combined mechanical and vacuum advance of 39 degrees.
    If I should be getting 30 degrees of centrifugal advance, what is limiting my distributor? Could it be the configuration of the weights? The distributor has been disassembled, cleaned, small parts (washers etc.) replaced and no binding or excessive wear is evident. The car seems to accelerate and run just fine.
    Any ideas would be appreciated.
    • 15610
    • Robert G.
      • May 31, 1990
      • 429
      • Michael M.
        • February 7, 2011
        • 186
        • William C.
          • May 31, 1975
          • 6037
          Bill Clupper #618
          • Michael M.
            • February 7, 2011
            • 186
            • William C.
              • May 31, 1975
              • 6037
              Bill Clupper #618
              • Larry M.
                • January 1, 1992
                • 2688
                Originally posted by William Clupper (618)
                At least based on my experience, you have a later model set of weights and the cam attached to the mainshaft is not what I would expect to see on a '67. I used to get my drinking money in the early 70's fixing these distributors on my machine.
                Agree with Bill. Many of these parts are not from 1967.
                There are a few folks in the Driveline and in Hemmings that rework/rebuild distributors and have the parts and test equipment. Need to contact one of them.
                Larry
                  • 15610
                  • Michael M.
                    • February 7, 2011
                    • 186
                    • John D.
                      • December 1, 1979
                      • 5507
                      • Gerard F.
                        • June 30, 2004
                        • 3803
                        Someone with a known original '67 300 or 350 HP dist. might be able to provide more info. I believe the 300 and 350 HP engine distributors were the same except the VAC. They both have the same centrifugal curve specs.
                        Michael, Duke,
                        Here's some pictures of an original 67 300 distributor with the top cams. Known to me to be the original from my 67, before I changed the shaft for the bunged up tach drive. This is a 30d centrifugal advance distributor really untouched:
                        The weights and top cam on the shaft sure look different from Michael's pictures.
                        I got a replacement shaft for the bunged up crossgear that looks just like the original as far as the top cam goes. I then put the original weights and springs back on.
                        The thing works perfect now.
                        Jerry Fuccillo
                        • Gerard F.
                          • June 30, 2004
                          • 3803
                          Jerry Fuccillo
                          • Michael M.
                            • February 7, 2011
                            • 186
                            • David L.
                              • July 31, 1980
                              • 3310
