Rear Shock Absorbers
Joe,
First picture below is of AC Delco rear shocks #88945172.
About the paint on rear shocks, I read that the upper bushing is painted gray with the rest of the shock, but the lower shock grommets were installed at St. Louis and therefore are not painted.
If I understand correctly, I need to press out the lower bushings and replace with the bushings in pictures #2-4 below. Two of these lower shock bushings are slightly taller, two are shorter, but the AIM calls out the same P/N for all four (GM 3735334). Should they not all be the same size?
Is it correct that the rear UPPER shock bushings are okay as-is, or should they be replaced too? I see that LIC offers a set with a metal core/tube for the rear shock Upper bushing (LIC 51-54C), but it looks like it will be hidden by the frame bracket anyway?
Joe,
