1960 VIN/Serial No. Tag
Re: 1960 VIN/Serial No. Tag
The three tags that Ed has shown are correct and they are made from aluminum. When they went to the steering column, they were stainless and spot welded. No pop rivets. Donald you tag appears to be a reproduction to me. The raised ridge goes all around except where the spot welds are. Ed's first post with the tag on the column spot welded show a correct later 60 tag.- Top
I agree that mine is probably a reproduction, so it seems that someone does make reproduction VIN tags. I'm hoping that someone make one that is like a correct one with the ridge around all four sides.The three tags that Ed has shown are correct and they are made from aluminum. When they went to the steering column, they were stainless and spot welded. No pop rivets. Donald you tag apears to be a reproduction to me. The raised ridge goes all around except where the spot welds are. One of the posts above did show a correct tag.Don Harris
Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)- Top
Donald,
Here's a photo of my VIN tag; like the ones shown in Ed's reply. It's an early '60, so the VIN tag is mounted inside the driver's door jamb. Hope this helps.
PeteAttached Files- Top
Thanks all. I think I have a more correct reproduction coming. Hopefully it will look more line the original shouldDon Harris
