I have a 69 427/390HP with auto and 3.08 rear end. I considering a rebuild and these are the suggestions I have from a local build. I have an estimated 8:1 current compression from a mechanic in AZ based on his dyno tune activities a how far he could retard the timing. Major points are:
Consider a roller cam which requires removal of the intake manifold heat shield and adds $800
Max 10:1 compression; maybe ~ 9.8:1
Add different oil system to the valve train
Heads: 3-cut valve job + venturi cut on exhaust
New pistons, rod bolts and head bolts
Keep rods; x-ray and balance full set up
Line bore and deck block except for pad
Since I have a late Nov build with 454 heads; consider a 454 crank
Have the auto trans checked and re-sealed while the engine is out
