The 1958 - 1960 Tech Info Manual & Judging Guide states that a foam filter was used "during early 1960." Foam element was "L" shaped in cross section. Corvette Central is selling a "correct" gray foam filter element, but it does not appear to be "L" shaped in cross section. Has anyone purchased one of their foam elements? Was it "L" shaped or straight sided?
Anyone have an opinion on the original being "L" shaped? I don't want to spend $16 if the foam element is not correct. Since my 1960 is car #1627, I believe it had the two piece air filter unit. Paragon states that the change started after car #900. Not sure where they derived that info.
, although as Bruce said I think a paper replacement would last longer for driving. If your cleaner is two piece and calls for an element I believe it is disassembled and judged.
