looking for the part numbers for the current gm door hinge pins and bushings for my 63 conv.. Thanks for your help Ed.
Door hinge pins and bushings parts no. help
Re: Door hinge pins and bushings parts no. help
Ed----
The bushings are GM #9721917. There are no pins currently available from GM for your application.In Appreciation of John Hinckley- Top
Joe,
I just got a quote for my 66 the other day from my local dealer. the pins are 20046147 listed as years 73-82. I suspect these are the correct diameter pins but longer than original and have to be cut. So I have read in the archives as I am planning on doing this.
Randy- Top
Joe,
Randy
Randy------
The GM #20046147 may work for C2's but they were never cataloged by GM for that application. Even for C3 applications they are considerably longer than the original pins and must be cut to proper length. Whether, or not, that's the only problem for C2 applications I do not know.In Appreciation of John Hinckley- Top
- Top
Randy------
Joe, the C3 pins are what I was thinking, I can cut them down and make the same length.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
