Engine Starter Motor - NCRS Discussion Boards
  • Jorn J.
    • October 21, 2008
    • 142
    Hi again
    I have just mounted my new Starter with only 2 Bolts The last bolt, this in the top should be mounted from back and through the Bellhousing into the Starter, but its not possible to do that because all 3 Bolts have the same size but the "hole" in the bellhousing are too little??
    Other here on the Forum who have the same problem.
    C1, 1959 with powerglide.
  • Eric H.
    • January 1, 2000
    • 14
    Re: Engine Starter Motor
    Jorn:
    Make sure you have the correct hole. The bolts are all the same size. The one that comes from the rear also attaches the bracket for the road draft tube.
    Eric.
