62 brake line from master Cylinder to block - NCRS Discussion Boards
  • Anthony P.
    • June 27, 2010
    • 485
    Would someone please post a picture showing the brake line going from the master cylinder the the 1st block on the frame?
    I need to see how the bends go. It was originally incorrect on my car so I need a reference to verify it. I did look in the AIM, but a pic will help.
    Thanks again,
    Tony
  • Tom F.
    • September 20, 2009
    • 66
    Re: 62 brake line from master Cylinder to block
    Tony:
    Take a look at some of the aftermarket manufacturers such as Echlers they show a breakdown of all the steel lines. I'm sure you could find a diagram of the master clyinder to brake block.
    • David H.
      • November 11, 2009
      • 777
      This is from my brother's '62. Original m/c and line.
      Hope this helps some. If you need measurements just let me know.
      • Anthony P.
        • June 27, 2010
        • 485
        The Pictures do help.
        I do have a new line that I just received, but it does not line up correctly with the block/master cylinder, so I am trying to figure out how it should be bent how close it goes towards the clutch support, etc..
        When I got the car, the brake line was exiting the master cylinder on the bottom, however, I am 99% sure it should attach to the drivers side on the front brass block block.
        Thanks for the info.
        Tony
        • Jerry W.
          • January 27, 2009
          • 588
          Don't have a good pic of our 62 but it is connected to M/C and looks similarly bent like David's pic
          • Jerry W.
            • January 27, 2009
            • 588
            Best pic i could find
            • Anthony P.
              • June 27, 2010
              • 485
              Thank you. All of the info in this thread has answered my question...
              Tony
