Hoping some engine guys can give me some ideas.
I am working on an engine that missed badly, but didn't knock.
I finally took the valve covers off and observed the #1, #7 and #4 intake rockers weren't touching the pushrods.
The pressed in studs for those 3 rockers were also about 1/2 inch longer than the studs for the rest of the rockers.
The former owner said "It had bad gas at one time, and I drained it all out."
Theory: Did the "bad gas" varnish up and cause the 3 above mentioned intake valves to seize, and when he tried to start it, the lifter/pushrod/rocker forced the rocker stud out of the head?
Here's where my real concern lies. I adjusted the rockers to take up the gap. I turned it over several times, and all the valves moved up and down perfectly. I then started it. It ran smooth, with no miss, but it was knocking. It never knocked before. I then replaced the 3 lifters, thinking they had been collapsed/broken. Started it again, and it still knocks.
Did I ruin something, or was the damage done before, and it just showed up after I allowed the valve to function which resulted in proper combustion and power stroke.
I sure hope you can show me I didn't do the damage.
Thanks!
Thanks!
