Advice for starting the engine for the 1st time? - NCRS Discussion Boards
  • Patrick N.
    • March 10, 2008
    • 951
    Hi all, after a good 3 years, I am very close to completing the rolling chassis and was looking for advice on the process for shaking down the engine with the body off. I recall a similar thread a few months back but can't locate it if anyone has a link?
    What are the do's and don'ts and good advice associated with running the motor this way? BTW engine, carbs, trans all rebuilt but not fired up yet. Any pit-falls to avoid?
    Advice welcome-
    thanks as always
    Pat
    68 427 400hp
    88
  • Alexander C.
    • June 20, 2010
    • 353
    Re: Advice for starting the engine for the 1st time?
    I could spew on and on but what I'll say now is the second the engine fires, watch the oil pressure gauge as you are bringing up the RPM to break in the cam/lifters!
    • Jerry W.
      • January 27, 2009
      • 588
      https://www.forums.ncrs.org/showthread.php?t=85449&uid=1300
      • Ray K.
        • July 31, 1985
        • 369
        " Prime " the oil pump manually before you fire it.
        Ray
        • Patrick N.
          • March 10, 2008
          • 951
          thanks guys, great points! Thanks for the link Jerry, that is a good example and issue to double check.
          I expect there will be a list of things that will need to be debugged, but hope to get a good start and validate that the engien is running good.
          thanks again,
          pat
          • Clem Z.
            • January 1, 2006
            • 9427
            make sure you have oil in the transmission.
            • Jerry B.
              • August 31, 1994
              • 416
              I think it is a good idea to ground the coil and bring up the oil pressure before the first firing.
              • Patrick N.
                • March 10, 2008
                • 951
                Does the AIM have a reference for starting, tuning and verifying the engine is operating within specs?
                • Joe R.
                  • May 31, 2006
                  • 1822
                  Jerry,
                  That's not such a good idea. Did you mean to say disconnect the coil to cap wire? That's a much better idea.
                  Joe
                  • Joe R.
                    • May 31, 2006
                    • 1822
                    Advice welcome-
                    thanks as always
                    Pat
                    68 427 400hp
                    88
                    Pat,
                    Here's a link to a thread similar to yours:
                    https://www.forums.ncrs.org/showthre...=2667&uid=1346
                    Which car are we talking about here? I assume the 68. What cam are you using? I would recommend following the cam mfr.'s break-in procedure. I am planning to use CJ-4 oil plus a can of the GM Engine Oil Supplement for my break-in. I saw a thread about this a while back, I'll see if I can find it.
                    Edit: Here's the other thread I was thinking of:
                    https://www.forums.ncrs.org/showthre...=2667&uid=6935
                    Joe
                    • Chuck S.
                      • April 1, 1992
                      • 4668
                      Tracy Crisler found this thread in a recent thread by Tom Hendricks.
                      https://www.forums.ncrs.org/showthre...break&uid=7564
                      The topic was cam break in...some good info. Beyond cam break in, most of us know what's needed to run an engine if we think it through. I try to think through complicated processes thoroughly several times to avoid forgetting something, and use that to develop a written check list. Putting oil in the transmission to lube moving parts is a good point some of us could overlook.
                      I'm sure there's more more info in the archives on initial engine start, but mining it out with the search engine, which "matches each word", is another matter.
                      • Ronald L.
                        • October 18, 2009
                        • 3248
                        Grounding the coil wire is normal as a part of tune up compression tests, etc. You ground the output side. Grounding the input is a direct short.'
                        I assume you have a good radiator set up stabilised with some sort of fabricated support structure??? fan & clutch on the engine?
                        Get a battery charger on your power source, and spin the motor, easier if you do this w/o plugs as there will be no compression load. What motor? Cold oil takes several minutes to get up to the top of a BB so its important to have used moly in the rebuild and pre lube the valve train. Get a $15 oil gauge and have that up on the motor, a lot easier with the remote start button. Spinning w/o plugs will tell you the system is ready to really fire up.
                        In this initial spin process have that 5 gallon can of fuel & hose into same so that fuel pump movement will have pulled fuel into the carb.
                        Make sure you have this on secure jack stands and the drive line in neutral. If on the ground, verify neutral, blocked for non movement.
                        Have your tune up box and timing light pre set up and connected.
                        Fire away - fun first start ups!
                        • Chuck S.
                          • April 1, 1992
                          • 4668
                          Originally posted by Joe Raine (45823)
                          Jerry,
                          Joe
                          A even better approach is to simply use a distributor shaft adapter and electric drill as suggested above to prime the pump and fill the galleries and bearings (i.e. build oil pressure) just prior to start. I'm not sure that preventing the engine from firing while cranking really lessens the concern about lack of lubrication during early cranking.
                          Assembly lube will probably prevent damage from "dry" cranking, but my preference would be to spend a few bucks for the adapter and know that the bearings will have a good oil film the instant cranking begins...one anxiety gone.
                          • Joe R.
                            • May 31, 2006
                            • 1822
                            Ron,
                            I think you have your inputs and outputs reversed. It's not a good idea to ground an output, unless you are certain that it is short circuit protected.
                            Joe
                            • Joe R.
                              • May 31, 2006
                              • 1822
                              Chuck,
                              I was not trying to imply that the pre-lube with a distributor adapter step should be skipped. I was just saying that shorting the coil is not so good.
                              Joe
