Radio Wiring - NCRS Discussion Boards
Radio Wiring
  • Dave G.
    • February 21, 2007
    • 14
    Radio Wiring
    I'm installing a Secret Audio radio in my 64 and needed to know what the three wires going to the stock radio are.
    Yellow/Black =
    Black (2) =
    Gray =
    Thanks for your help.
    Re: Radio Wiring
    Yellow/Black =
    Black (2) =
    Gray =
    Dave -
    Yellow/black is 12V ignition-switched power.
    Black is ground. NOTE: That wire grounds everything from the firewall to the rear of the car, through the second pigtail exiting the center cavity in the connector with a ring terminal that screws to the bottom of the lower instrument panel brace just to the left of the radio.
    Gray is the radio dial light.
