58 Coil Ballast Resistor wiring - NCRS Discussion Boards
  • Brad H.
    • August 12, 2007
    • 724
    I noticed that my wiring at the resistor is 2 greens and the W.W. motor wire on the drivers side, and the dark brown wire on the pass. side, isnt it suppose to be 2 greens on pass side and dark brown and w.w.motor wire on the driver side? 283/230. Thanks, Brad.
  • Philip P.
    • February 28, 2011
    • 558
    Re: 58 Coil Ballast Resistor wiring
    It will not make a difference electrically, it may have been replaced and the wires connected that way.
    Phil
    1960/230
