tack cable - NCRS Discussion Boards
tack cable
  • Wayne G.
    • May 4, 2011
    • 75
    tack cable
    60 vette fi...
    what is the correct sealant to use to hold the large foam peice that the tack cable goes thru. Seems at one time it was removed and I am taking it the cable goes thru this foam peice. Amazing its not all dried out, Looks almost like weather strip material. I can see it was sealed with what looks like some form of a putty? I am trying to redo the seals on the firewall, so far Krytox has softened all of them back to life, that stuff is just amazing.
    There appears to be a larger hole in the firewall on the drivers side of the tack rubber gasket were the cable was run. I am thinking either there was something else thru it, or the cable just wore a little of the fiberglass away, anyone have pics of what is should look like?
    thanks.
  • Terry D.
    • May 31, 1987
    • 2690
    Re: tack cable
    Wayne
    An assembly manual should show this in pretty good detail, at least the 61-62 manual does.
