Aluminum Radiator / Brass Petcock - NCRS Discussion Boards
  • Jimmy G.
    • November 1, 1979
    • 975
    Pros and cons from some experienced NCRS chemists / engineers. OK to run brass with aluminum??
  • Jim L.
    • September 30, 1979
    • 1805
    Re: Aluminum Radiator / Brass Petcock
    I wouldn't do it. Galvanic corrosion is real. Aluminum petcocks are readily available and that's what should be used.
    Jim
    • Larry M.
      • January 1, 1992
      • 2688
      Have had a brass petcock in my OEM Harrison aluminum radiator for over 20 years. No apparent problems or leaks.
      However, as Jim says, having same or similar metals is always advisable.
      Larry
      • Jimmy G.
        • November 1, 1979
        • 975
        Does NAPA or Pep Boys sell an aluminum one. I tried several places with no luck.
          Jimmy -
          Tom DeWitt has them (www.dewitts.com).
          • Mike E.
            • February 28, 1975
            • 5134
            I'd spend the extra bucks and get the aluminum--bad experience back in the 70's with brass on aluminum.
            • David K.
              • February 1, 1976
              • 592
              I went absolutely bonkers, trying to get a GOOD aluminum petcock.After MANY attempts I finally got a good one, but it was sure tempting to just get an aluminum plug. The petcocks would all just seize. This was before they were even used. I can't remember what happened anymore to get a good one, but it was an ordeal! Yes, new radiator and new petcock in 2008.
              • Stuart F.
                • August 31, 1996
                • 4676
                My experience with aluminum petcocks is to use them as plugs. They will then look right and, if you remove amd apply using the hex portion, they will last a long time. Took me about 3 ruined ones to figure this out. They do seize and you'll spin the handle off trying to unseize them, having to open them as a plug anyway.
                Stu Fox
                  Jimmy------
                  Keep this in mind: GM did not use special aluminum petcocks with aluminum radiators because the ordinary and mass-produced brass ones would work just as well.
                  • Joe R.
                    • July 31, 1976
                    • 4547
                    Jimmy------
                    "Huh"!!! What did you say again please?
                    JR
                      JR
                      JR-------
                      "Translation": If GM had determined that there was no problem using a standard brass petcock with an aluminum radiator, they would not have gone to the expense of creating a specification and part manufacturing order for a special, extremely limited-use petcock utilizing an aluminum body.
