Splash pan paint - NCRS Discussion Boards
Splash pan paint
  • David H.
    • November 11, 2009
    • 777
    Splash pan paint
    Not finding anything specific on the paint for the splash pans on my '62. I am assuming flat black on both sides like the paint for the engine compartment?
    Re: Splash pan paint
    David -
    The sheet metal splash pans were processed through the same high-volume flow-coat/dip black prime system as the fan shroud, which produced a semi-gloss appearance.
    The engine compartment blackout was sprayed, with flattened black lacquer, resulting in a semi-flat "eggshell" sheen.
    • David H.
      • November 11, 2009
      • 777
      Thank you John,
      I thought I had seen them with the semi-gloss but could not find it anywhere to prove it.
