These clutch pedal brackets apparently have 2 ways to attach the mounting bolts. The lower bolt is through a elongated slot and the upper bolt appears to be able to go into either of the the 2 holes.
What is the reason for having 2 holes?
And which hole was originally used, the inboard hole or the outboard one?
Thank you,
Ralph
Thank you,
Ralph
