Re:2x4 intake manifold - NCRS Discussion Boards
  • Jerry B.
    • August 31, 1994
    • 416
    I'm in the process of restoring a 57 manifold. My question is how much can be machined from the gasket surfaces for a leak free fit. THe current surfaces are in need of resurfacing. As far as I know, the engine has not been decked. Need some specs. Thanks
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: 2x4 intake manifold
    if you cut the manifold you will need a thicker intake gasket to get the bolt holes to align because it will drop down farther into the valley between the heads. i just use a body shop sanding board to clean up intakes.
    • Jerry B.
      • August 31, 1994
      • 416
      Thanks Clem I will use the file method
      • Clem Z.
        • January 1, 2006
        • 9427
        if you do need to cut the manifold there are extra thick gaskets but they are after market. i guess you could glue 2 stock gaskets together if you had too
        • Bruce B.
          • May 31, 1996
          • 2930
          During a recent project I looked into intake gaskets.
          The typical gasket is specified at around 0.062".
          If a thicker one is needed a few racers suggested gluing 2 of these gaskets together using weatherstrip adhesive.
          The other option is Jegs or Summit ( or other parts suppliers) who sells a FelPro gasket which is 0.120" thick. I think the pn is FP1245.
          But in my opinion cleaning up with a file or a sanding board should be sufficient.
