Jack for my 66 - NCRS Discussion Boards
Jack for my 66
  • Donald H.
    • November 2, 2009
    • 2580
    Jack for my 66
    My car did not come with a jack so I need to buy one. Has anyone bought and used the reproduction jacks like Paragon and Corvette Central sell?
    Their websites basically say that their reproduction jacks are built better than the originals, but the recommend that they be used only for show and not to jack up the car.
    If they are better than originals and the originals where what were used to jack up the cars, then why shouldn't they be used now? Are they just making a liability disclaimer with their statements?
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
    Re: Jack for my 66
    Don
    Don -
    Yes. The reproduction jacks are no less capable than the originals. Ever count the number of death, doom, and destruction stickers on a ladder?
    • Harry S.
      • July 31, 2002
      • 5258
      Re: Jack for my 66
      Show only!!!! Unless you carry a jack stand to support the car after you get it up, and that is still risky.
      You probably need a Type III jack. Take a look at LIC's pictures.
      • Don H.
        Moderator
        • June 16, 2009
        • 2236
        Re: Jack for my 66
        It seems to me that if you own a driver, and you get a flat and have to make a tire change, and you do not have AAA roadside service, you are probably going to have to use the service jack that came with the car. And I'll bet if you are parked on a relatively flat road surface, and you are careful to block wheels to prevent car from rolling, that the service jack will lift the car just fine to allow for changing the wheel. Now I have not done it because no flat tires yet, but I don't see any great risk should I have to. The jack seems plenty sturdy to me for emergency use.
        • Bob S.
          • January 1, 2004
          • 181
          Re: Jack for my 66
          Donald-
          In good condition, the service jack is a fine, but not the easiest way to lift your car. As others have said, you always want additional support before going under the car though.
          Back in the day, all I had was the service jack and a similar, but slightly larger FLAPs sissors jack for lifting my midyears. Used both many times for oil changes, replacing clutches, cams, etc.. The FLAPs jack finally wore out due to thread wear......so I'd recommend making sure the threads are lubed with clean chassis grease on any service jack that is used.
          Haven't used a Corvette service jack for nearly 30 years. Been using floor jacks since, and now enjoy using my Rotary lift.....
          Bob
          • Donald H.
            • November 2, 2009
            • 2580
            Re: Jack for my 66
            Originally posted by Bob Schaefer (41225)
            Donald-
            Bob
            I'm only looking at a reproduction jack to carry in the car for emergency. I have floor jacks and jack stand to work under the car. Hopefully will be getting a lift in the near future.
            Don Harris
            • John C.
              • January 1, 2005
              • 616
              Re: Jack for my 66
              Don
              If you only want the jack for emergency purposes I suggest you go with a 69 and up jack. They are built much more heavily then the mid year styles. You should be able to find a good used one for a lot less then the reproductions are going for.
              John
              • Joe R.
                • July 31, 1976
                • 4547
                Re: Jack for my 66
                I have had several long discussions with John Smith (former owner of the company that builds reproduction jacks). The jacks are not only as safe but safer than the originals since they are constructed of better grade steel, rivets, bearings etc. The reason for the warning with the jacks is that they are selling them to idiots! These idiots think that they can use a jack on any surface, at any angle and the jack will not fold under the pressure.
                Well they are wrong, hence the warning to protect the manufacturer from wrongful lawsuits from the lawyers that come out from under the rocks.
                In a nutshell, get you a reproduction jack (Type III) and use it correctly and use your lift, floor jack and stands for oil changes and repairs.
                Have a nice day,
                JR
                • Paul J.
                  • September 9, 2008
                  • 2091
                  Re: Jack for my 66
                  Don,
                  There's nothing wrong with a Type III service jack for a roadside emergency. All that you need is for it to function well enough to get you back on the road, which is about all it does. The reproductions should work fine, just remember to be careful with it. It will also fit into the storage well. Chances are you'll never use it on a car that has very good tires and is driven infrequently.
                  I have used mine many times, although it was a long time ago. Between my boys and thier friends, we now have 24 hour roadside assistance (free). One of the benefits of living out in the country.
                  Paul
                  • Dan H.
                    • July 31, 1977
                    • 1365
                    Re: Jack for my 66
                    Guys, just to prove how good those original jacks were, I was watching Route 66 last night and Todd had his 63 vert jacked up with the jack, had dismounted a tire and was using the bare wheel as a winch to pull some people up a cliff! Must not have had positraction? The jack was almost totally extended, can we say 'scary'?
                    Dan
                    1964 Red FI Coupe, DUNTOV '09
                    • Donald H.
                      • November 2, 2009
                      • 2580
                      Re: Jack for my 66
                      Have a nice day,
                      JR
                      I assumed the reproduction were as good as the original jacks. Would sort of have to be given todays litiguous society. I don't plan to have a flat, so it will not get much use anyway.
                      Don
                      Don Harris
                      • Don H.
                        Moderator
                        • June 16, 2009
                        • 2236
                        Re: Jack for my 66
                        Hey Don
                        that's the thing about flats,,,,
                        no one plans to have them.
                        They just happen.
                        And at the most inopportune times, usually.
                        Buy the repro jack, put it in the well, and you are good to go.
                        If you want to be doubly good, get AAA roadside service.
                        Happy motoring!
                        • Jack P.
                          • March 19, 2009
                          • 1135
                          Re: Jack for my 66
                          Don
                          Owned my car for 41 years (66) and threw out the original jack 40 year ago. I always had a small bottle hydraulic jack and a piece of wood to put it on. Lifted the car to change tire.
                          Traveled all 48 states last summer , without a spare tire or jack. Just carried a few cans of fix flat and had my AAA card.
                          If you are going to use a jack, get a hydraulic one, much safer.
                          Jack
                          • Bill W.
                            • November 1, 1977
                            • 402
                            Re: Jack for my 66
                            Jack
                            Guys,
                            My original jack gave up the ghost about the tenth time I used it. If you have one of these be careful when useing it. Bill
