C2 and C3 spare tire size - NCRS Discussion Boards
  • James H.
    • February 22, 2007
    • 130
    I've been driving the 68 and 67 without a spare. So far so good. I went to local tire store and bought two cheap radials for each and they don't fit into the tubs. Not even close. Do I have to buy reproductions of originals or has anyone had any luck with narrow radials? If so what worked for you.
    Jim
  • Michael G.
    • January 1, 1997
    • 1251
    Re: C2 and C3 spare tire size
    James,
    Any 205 x 70 or 75 should fit the bucket.
      • 43193
      Jim
      Jim------
      What size tires did you buy?
      • Kevin N.
        • September 30, 2002
        • 88
        i have a uniroyal 205/75r/15 in my 66 tub with no problems.
        • James H.
          • February 22, 2007
          • 130
          I bought P225/70 for the 68
          P205/75 for the 67
          Both on correct size rallies and neither come close to fitting. Even thought about using longer bolts on the hinge side of tub to give me more room.
          Did these cars have the same size rally for a spair?
          Thanks all,
          • Russ S.
            • April 30, 1982
            • 2161
            Do you have 6 inch wheel for the 67 and a 7 inch for the 68?
              P205/75 for the 67
              Thanks all,
              James -
              I have a 205/75-15 Firestone Supreme Si on a 6" N89 bolt-on aluminum rim on my '67 (same as my road tires), and it just fits; I have the "long" front hanger bolts, and the tray has about a 3/4" gap to the bottom edge of the tub at the rear. Note that I have a reproduction tub, which is slightly larger in diameter than the original; many original tubs won't accept any kind of 205/75-15 tire.
              A common "fix" for a functional spare tire is to use a late 90's S-10 truck compact spare (T155/60D15); same bolt pattern, and the wheel clears the Corvette caliper.
