In the past I have recommended to L-79 owners who want to maximize the broad range torque/power of their engines, but lose no judging points and pass a PV to either use the OE L-79 cam or the LT-1 cam in conjunction with massaged heads and a properly managed compression ratio.
Some were reluctant to install the LT-1 cam due to the mechanical lifters, and I wasn't sure if a L-79 with LT-1 cam could make it through a PV even with lash adjusted lash to my specifications, which pretty much eliminates valve clatter, but it leaves the engine with a more aggressive idle that might result in a PV failure.
The L-79 cam is a very good design for the OE heads, but is not optimized for massaged heads with their typical E/I flow ratio.
So I began swapping OE lobes around and came up with a design that uses either the L-79 lobe or the L-46/82 inlet lobe on the inlet side and the "300 HP cam" inlet lobe on the exhaust side with the same or slightly less than OE effective overlap and a fairly late inlet POML.
The gains are not dramatic, but both low end torque and top end power are improved with a useable power bandwidth to lifter pump up speed, which should be at least 6500 with properly setup OE valve springs.
If anyone has a L-79 engine restoration planned for the future and you want to consider this new design, get in touch with me.
