Clear coat engine and components - NCRS Discussion Boards
  • Steve D.
    • May 16, 2011
    • 106
    Do you guys clear coat things like valve covers,firewall brackets etc. How about alternator,a/c and power steeering brackets? I know they were dipped so I doubt they recieved any additional protection.
    Also if you do use clearcoat, would you use the satin to keep the correct finish on semi-gloss pieces?
  • Domenic T.
    • January 29, 2010
    • 2452
    Re: Clear coat engine and components
    Only if you want them to look good for a LONG time.
    DOM
      • 6940
      Steve, the factory doesn't use clear on anything, but as Dom says it help preserve the look and helps with rust. if the car is judged there maybe a small deduct, If the judges catches it. and Satin is the only way to go.
        • 3415
        Hi Steve,
        You mention "correct finish on semi-gloss pieces".
        I don't see much advantage to using clear on painted parts; but do see an advantage to using a minimal amount of clear on parts that left St. Louis natural, in order to help control rust. For instance half-shafts.
        • Bruce B.
          • May 31, 1996
          • 2930
          Years ago on my 62 I bead blasted the valve covers and sprayed them using an catalyzed clearcoat. They still look great and clean easily.
          I also used clear on my 57. I cleared the cast iron front suspension parts and the rear center section because I wanted to see the inspection marks.
          • Duane D.
            • April 15, 2009
            • 67
            Steve, I coat my bare metal parts with hand-rubbed tung oil. It is easy to apply, prevents rust and looks natural. It's great for fasteners, clamps, etc.
            Duane Dunlap
            • Rich C.
              • January 1, 1994
              • 383
              Duane Dunlap
              I've never heard of that one! How does it hold up to underhood heat? When I turn off my '73 454, I could heat the house!
              • Michael G.
                • November 12, 2008
                • 2155
                Natural steel components can be clear-coated with flat, they look better than if done with satin.
                • Duane D.
                  • April 15, 2009
                  • 67
                  Rich, Tung oil works well for suspension components and various fasteners even in the engine bay, but not for very hot areas like exhaust manifolds. You can dull the finish with a fine piece of steel wool. I also used it to coat bare drive shafts. Duane
