1967 original glass - NCRS Discussion Boards
1967 original glass
  • Michael M.
    • June 30, 1997
    • 97
    1967 original glass
    Need some advice. I have been performing a frame off restoration to my 67 #276. The glass is original with date codes and are as follows: front UA, rear LA. It unfortunatly has some wiper smear and minor scratchs in both the front and rear i.e. ice scapper etc. You can't feel them with your nail but I've tried using Groit's glass polish and polishing pads, it looks better, but they are still visible and will not compare to the rest of the car upon final assembly.
    Should I install as is and take deduction for condition and by the way what is the deduction for this condition ?
    Other alternative is to replace with correct date coded glass and get a deduction for the replacement glass.
    My understanding is that know one makes the glass with the proper tint line. Who would be the best source for this purchase?
    Trying to evauate my options, points deduction on condition vs points on replacement part?
    Thanks in advance for the input!
  • John M.
    • June 27, 2010
    • 179
    Re: 1967 original glass
    mike I'm in the same boat as you, I've called every glass shop in Jacksonville and no one can help. I'm going to clean it the best I can and reuse. I rather have my original glass which is tinted. Not much help but I'm sure we are not the only two in this boat.
    • William W.
      Infrequent User
      • October 27, 2010
      • 2
      Hi Mike: I faced this same dilema several months ago and found a local glass polishing service that compltely removed all the surface scratches from my windsheild. I tried several commercial polishes myself and never got close to the results the professional acheived . The guy that did mine specialized in removing grafiti from buildings, you might try that type of search locally. The process took several hours and controlling heat build up was his pirority . If you do a search for windsheild polishing success I posted several pictures showing the process. Good luck, keep your original if you can.
      • Tim G.
        • March 1, 1990
        • 1358
        I have a good size stone chip right on the drivers side, but with 22,000 miles, I just have to leave it alone.
        • Joe R.
          • March 1, 2002
          • 1356
          Hi Michael:
          When I bought my 67 it had extensive wiper scratches in the original windshield. They were not deep enough to catch a fingernail, which is the often-cited test to determine whether a scratch is too deep to polish out.
          I purchased the Eastwood glass polishing kit that consists of a special fiber pad that mounts in an angle grinder, plus a jar of polishing compound. After reading the instructions I found that the recommended speed for the angle grinder is slower than the fixed-speed grinders, so I bought a variable-speed grinder (which cost much more than the Eastwood kit).
          The good news is that I was able to polish out 100% of the scratches. The bad news is that it took me an entire day to do it. Progress is very slow and you have to be ultra-careful to avoid local heat build-up, or you can crack the glass.
          If you are patient and persistant, I recommend using this method. If you are not patient and persistant, take the car to a glass shop that offers this type of polishing service.
          The key thing to know is that if the scratch is not deep enough to catch a fingernail, it *can* be polished out.
          • Ara G.
            • January 31, 2008
            • 1108
            Mike
            My 2 cents would be to reuse your original glass...I would much rather have my original glass with original logo's and original dates than a reproduced one without any scratches...In fact, some judges may give you a "pass" on a scratch or two respecting the fact that it's the original...or maybe a dot at worst where if the same judge saw a repro glass with a NTP logo, then you're going to get a point or 2 deduct...Just my two cents...Having original glass in a car is a real bragging right....Good luck with your car....nice early car too....ARA
            • William C.
              • July 15, 2009
              • 239
              Originally posted by Joe Randolph (37610)
              Hi Michael:
              Michael..I too have had the same success as Joe on 2 windshields with Eastwood..Bill
              • Russ S.
                • April 30, 1982
                • 2161
                The stone chip can be repaired nicely by one of those guys you see under tents in parking lots repairing windshield chips before they become cracks.
                • Alton J.
                  • June 19, 2011
                  • 32
                  Is Paragon's reproduction glass good enough ?
                  • Martin T.
                    • May 31, 2006
                    • 196
                    Mike, Which company did you decide to go with? I am in need of glass and had planned on OEM but......
                    • Michael M.
                      • June 30, 1997
                      • 97
                      Pilkington
                      800-848-1351
                      Good people to deal with.
                      Quality, correct product, well satisfied
                      • Al R.
                        • June 30, 1988
                        • 687
                        I agree with Pilkington glass
                        • Chris E.
                          • November 3, 2006
                          • 1322
                          Leave the original glass in. Depending on how bad the scratch or chip is, you'll probably only get a 1-3 point loss for condition.
                          A reproduction windshield with the wrong tint band was regularly getting a 10 point deduct in Regional judging on my car.
                          Chris Enstrom
                          2011 Z06, red/red
