Hey Guys,
Trying to get my fan shroud bolts straightened out. In the AIM on page A4 it shows a bolt (122007), lock washer (103320) and "U" nut (3792259). I think I get those being a WB headmark bolt and the square fixed nut "U" bolt that slides onto the fiberglass of the fan shroud. Pictures of original bolt and U-nut would be appreciated to confirm.
My real question is with the horn mount on the DS. That bolt is listed on AIM page A5 as 3848408, so clearly different from other fan shroud bolts. No lock washer is listed although the pic of the bolt seems to show an integral washer. The attachment to the shroud is called out as a weld nut - is that the same thing as the U-nuts used above?
I would really appreciate if someone could describe and/or post a pic of the original bolt used to mount the horn and then clear up the "weld nut" thing for me as well.
Thanks.
Kirk
67 327/300hp with AC
Thanks.
Kirk
riginal fan shroud hole was then used to mount the DS horn ON CARS WITH AC. There were a number of 67 AC car owners who chimed in that that was exactly how their cars were too.
