According to my GPS my 66 speedometer is reading about 15MPH low. Here is what I have:
The differential housing is stamped AM and dated 10 22 65. I don't know if it is original to the car. The car's birth date is July 66. The AM should translate to 3:36 posi. I will do the wheel / drive shaft rotation test when I have a chance to get under the car.
4 speed tranny and the tires are 205/75R15
I did a couple of checks against my GPS:
at 40MPH reading on the speedometer the GPS shows 56MPH.
at 2500RPM on the Tach, the GPS shows 61MPH. I used the Keisler website and its speed analyzer and it showed at 2500RPM and a Muncie in 4th gear with a 3:36 rear should be 60MPH. So maybe my speedometer is simply not calibrated correctly.
The driven gear in the transmission is blue, which I believe is 20 tooth. And I also believe this is correct for 3:36 rear. According to what I have read, adding a tooth should increase the speedometer 5MPH, so If I install a 23 tooth driven gear it should get my speedometer much closer to actual speed.
Does going to a Black 23 tooth driven gear sound Right?
Or, does it look like my Speedometer is just not calibrated correctly?
Don
Don
