Re: C2 speedometer driven gear help
Revs at 60 are (tire revs/mile) x axle ratio: 766 x 3.08 = 2359, which is why I think you might have a 3.08, but that assumes the tach is reasonably accurate, so you should test it against an accurate tech tach.
Pull the speedometer adapter out of the transmission, verify the color and tooth count of the driven gear, then look inside the transmission and record the color of the drive gear and if possible, count teeth on the drive gear.
There's really no point in speculating until your current configuration is verified.
, I figured it out. Mile divided by Tire circumference equals rev/mile. I measured the tire with a tape ( not the most accurate) and I got 27" so the rev/mile with this would be about 747 versus 766. I try to get a better measurement of the tire diameter
