Anyone know the specs for this control.
Vacuum advance D1383 GM1115360
In Appreciation of John Hinckley- Top
- Top
Re: Vacuum advance D1383 GM1115360
The data I have indicates that the recent aftermarket version is stamped "B10" and was available under NAPA Echlin number VC1765SP, however, I believe it's been discontinued.
This VAC was OE on L-72, and in lieu of it I recommend the B20 or B26, which has 16* @ 12".
I don't know if it was used on '70 LT-1, but the '70 AMA specs that you should be able to download from the GM Heritage Web site should include the VAC specs, which you can then match to a part number.
Duke- Top
The vacuum actuator used on the 1970 LT1 (distributor 1111491) uses a vacuum advance unit of 1116201. Jim this information is in the 1970-72 TIM&JG, and has been for a decade or more.
Your vacuum advance was used on a 1970 L46 (350/350) distributor number 1112021.
If you are using the Chevrolet parts book these two engines are differentiated by HP (350/350) and SHP (350/370)Terry- Top
Thaks Terry , ( Don't have a 1970-72 TIM&JG)The vacuum actuator used on the 1970 LT1 (distributor 1111491) uses a vacuum advance unit of 1116201. Jim this information is in the 1970-72 TIM&JG, and has been for a decade or more.
If you are using the Chevrolet parts book these two engines are differentiated by HP (350/350) and SHP (350/370)JR- Top
Jim, If you are looking for the applications for your 1115360 control, I don't want to mislead you. There may be many other applications than the 1970 Corvette L48 -- I just don't have easy access to that information, and since you asked about 1970 LT1 I went to the most readily available (to me) source..Terry- Top
