1972 - LT1 oil dip stick and tube - NCRS Discussion Boards
  • Jerome P.
    • October 22, 2006
    • 607
    The dip stick I have on my 72 has a small indentation just below the Farrel and the replacement I just purchased from Paragon does not have this indentation. I believe all other aspects of the Paragon dip stick are the same as the one currently on the car.
    What is correct?
    The tube I also purchased is a tin color, but almost bordering on a shiney finish. The one I currently have is a dark color almost black, but could be that it is just weathered, etc.
    What is correct?
  • Don L.
    • August 31, 2005
    • 1005
    Re: 1972 - LT1 oil dip stick and tube
    Jerome, can we see pics of both sticks?
    Don Lowe
    NCRS #44382
    Carolinas Chapter
    • Jerome P.
      • October 22, 2006
      • 607
      Well try to get pics of everything today. The car is in storage - 20 miles away, but will be going that way today. Thanks
      • Jerome P.
        • October 22, 2006
        • 607
        I miss spoke. The new dip stick has the dimple/indentation. I am not sure if the one on the left was orginal to the car, but it was on the car when I bought it 6 years ago.
        WHICH IS CORRECT?
        Attached are pics.
        Do you konw what color/finish the handle should have?
        Also I have attached a picture of the dip stick tube. I think it is to shiney. Your thoughts
        • David L.
          • July 31, 1980
          • 3310
          I believe the correct dipstick for the 1972 Corvette should be stamped "ADD", "FULL", "USE SE ENGINE OIL" as well as a "M" (or possibly "E", depending on the manufacturer) and WITHOUT the dimple in the handle. The "A" dimension should be 20 5/32" and the "B" dimension should be 20 59/64". The "M" dipsticks have a black plastic tip at the end of the loop on the handle.
          The 3862730 dipsticks sold over the counter in the 1980's are stamped "ADD 1 QT", "FULL", "USE SE ENGINE OIL", "3862730" and "M" and do have a "dimple" on the handle.
          I believe that the 1969-1971 dipsticks are stamped "ADD", "FULL", "USE GM6041-M-QUALITY MS OIL" and "M" (or possibly "E") WITHOUT the "dimple" on the handle.
          The 1965-1967 dipsticks were stamped "ADD", "FULL", "ENGINE OIL" and "M" with a black plastic tip on the handle.
          You should confirm my findings with others before spending any kind of serious money.
          The upper dipstick tube is GM # 3876784. I have several used original tubes if you need a photo. Is the top 2" of your upper tube smaller in diameter then the rest of the tube? I can't tell from your photo.
          Dave
          • Jerome P.
            • October 22, 2006
            • 607
            Yes the upper 2" of the tube is smaller in diameter.
            What are your thoughts on the finish? Like I said it looks a little too shiney. Do you have a picture of your original tubes that you could post.
            • David L.
              • July 31, 1980
              • 3310
              Jerry,
              My 3 used original 3876784 upper tubes have a dull gray finish. I also have a NOS upper tube for a 1967 Chevrolet 283/327 (GM # 3900428) and its finish is also dull gray. The 3900428 is 1/8" shorter then the 3876784 tubes, otherwise identical.
              Dave
                Originally posted by David Liukkonen (3775)
                Jerry,
                Dave
                Dave and Jerry------
                Keep one thing in mind: zinc air-oxidizes over time, whether the part is being used or whether it's sitting on a shelf. So, while the finish might be dull now, it might not originally have been as dull.
                • Kevin G.
                  • February 1, 2005
                  • 1074
                  Jerome,
                  Here's a few shots of what I believe to be the original from my 72 LT1 (5/10/72 build date).
                  Hope they are helpful!
                  • Jerome P.
                    • October 22, 2006
                    • 607
                    David/Kevin -- Thanks for the photos they are really helpful.
                    Kevin, my 72 LT1 is also an A/C car and has a build date of June 14, 1972 (engine stamp pad V0421CKY 12S523822).
                    What production no. is your LT1 car
                    Again thanks.
                    Jerry
                    • David L.
                      • July 31, 1980
                      • 3310
                      Kevin,
                      I also believe that the dipstick shown in your photos is original equipment for your 1972. The "ADD", "FULL", "USE SE ENGINE OIL", and "M" are correct for a 1972.
                      Dave
                      • Jeff A.
                        • January 1, 2000
                        • 312
                        In addition to the colored tip - a flat handle stick was also used.
                        Stick markings would be the same on both styles.
                        My Cars
                        • Jerome P.
                          • October 22, 2006
                          • 607
                          Are you saying these are from a '72?
                          • Jeff A.
                            • January 1, 2000
                            • 312
                            Yes - there were multiple vendors making dipsticks in 1972 and both styles were being used.
                            My Cars
                            • David L.
                              • July 31, 1980
                              • 3310
                              Jeff,
                              Does your dipstick with the handle with the "flat end" (instead of the black plastic tip end) have the letter "E" instead of the letter "M"?
                              Dave
