Jim Reinarts (36423) asked me if I had supporting information as to the direction and orientation of the shoulder bolts, lockwashers, and nuts that are used to assemble the 1963-1966 Corvette 5690809 Flange and Coupling Assembly (shown on my information drawing.)
This was my answer to him.
JR,
The following information is all that I can currently supply as to the orientation and location of the shoulder bolts and attaching nuts and lockwashers that are used to assemble the 5690809 flange and coupling assembly (cplg asm).
This cplg asm for the 63-66 (non-adjustable) standard Corvette steering column has the same flanges (5690811) on both the gear and steering column sides. So at that time 1963-1966 the steering gear input shaft and the standard Chevrolet steering column shaft were the same dimensions. So we can't draw any conclusions from those flanges as to direction of assembly.
Typically a Saginaw cplg asm had shoulder bolts oriented such that the nuts and lock washers assembled from the steering column side. This was because the cplg asm was normally assembled to the gear at Saginaw and the car assembly plant had easier access to assemble and torque the nuts and lock washers if they were located on the steering column side of the assembly.
However, way back in the middle 60's, if Saginaw assembled the 5690809 cplg asm to the gear and shipped it as a complete assembly to the Corvette assembly plant, the assembly plant wouldn't care about the location of the nuts and lockwashers since they were only installing and torquing the pinch bolt that attached the cplg asm to the steering column shaft.
One last observation, the Saginaw Product Engineering drawings typically had the gear attaching end pointing to the left. Was this a hard and fast rule? Was it hard and fast back in 1962-63 when the drawing was made? Unfortunately, none of the draftsmen and engineers that would have actually made the drawing(s) nearly 50 years ago (and might know the answer) are deceased.
Applying the above rule, the nuts would be on the gear side of the 5690809 cplg asm drawing.
I probably should not have labeled my information drawing for the 5690809 cplg asm with the "gear end" and "steering column end" called out. I cannot find any Saginaw drawing information that supports the orientation of the shoulder bolts and the location for the nuts and lockwashers. If further supporting information is available, maybe I can leave the drawing alone.
Jim Shea
JR,
Jim Shea
