C2 3367 Fuel Bowl Leak - NCRS Discussion Boards
  • Frank C.
    • August 31, 2003
    • 170
    The "plug" (I have attached a picture)on the side of my secondary fuel bowl is leaking. I researched the archives and it looks like a good fix is epoxy. Can I leave the plug in and just cover with epoxy after cleaning with acetone? Or do I need to remove the plug and then fill? If I do need to remove the plug, how is this done?
    Frank Clark
    U.S. Army Retired, current serving DoD Civilian
    C1 1962 300hp, 4spd. Black/Fawn
    C2 1966 Coupe, L79, A01, C60, J50, M21, N40. Silver/Black
    C20 1966 Custom Camper, L30, J70, M49, N40, G60, Saddle/White
    C20 1966 Custom Camper, L30, M49, N40, G60, Saddle/White
  • Michael M.
    • February 1, 1993
    • 603
    Re: C2 3367 Fuel Bowl Leak
    Frank, leave the plug in the bowl. Just work the epoxy in between the plug and the outer lip of the bowl.
    • Jim T.
      • March 1, 1993
      • 5351
      Not the same place as yours, but on top of my Holley fuel bowl I used JB Weld several months ago and it is not leaking.
      • Clem Z.
        • January 1, 2006
        • 9427
        i have been told by my contact a holley there is a "O" ring under that plug and soaking in carb cleaner destroys it. someone suggested using fuel proof clear model airplane dope as a sealer as it is not as visible as the epoxy. i have not tried that.
