Whistling Holley 4160 - NCRS Discussion Boards
  • William G.
    • December 1, 1988
    • 138
    Greetings:
    I THINK I've done a full job of searching the archives for this "teaser". A very disturbing high pitched whistle which seems to come from the area of the air horn/throttle bores. It commences at idle and up to fairly high engine speeds where other intake air flow sounds may drown it out. It is NOT present on initial startup up when the choke is on and restricting air flow. But the whistle gradually begins to be heard as soon as the choke starts to open and is quite loud when the choke is fully open. I've had carburetors with worn throttle shafts before but none that ever whistled and you'd think that an intake leak would be more likely to whistle when the choke is on rather than off.
    I've replaced the carb to intake gasket and all hoses and diaphragm checks made except the vacuum secondary. People I've talked with say that a vacuum leak is going to result in a very lean condition adveresly affecting driveability. But........such is not the case. And the plugs do not show a lean condition even after 100 plus miles driving (but then, at higher engine speeds perhaps the leak or escaping air is, in fact, not present?). I've also considered an air leak on the suction side of the pump introducing air into the bowls which is then escaping via the vents and causing the whistle. But I can't find a suction side leak and it doesn't run lean as you would expect with a suction leak.
    Last fall I had to replace the power valve and this spring I rebuilt the original 4657 fuel pump. But I don't see either of those causing the problem. Tiny piece of dirt in one of the vents.....perhaps? But I've never heard a whistle like this. This is a model 4160 Holley on a '66 300 hp.....List 3367. Any help?
    Thanks.
    Bill
  • Tom H.
    • December 1, 1993
    • 3440
    Re: Whistling Holley 4160
    I've heard of this before.
    The whistle may be coming from the bowl vent. Your float may be level off. Holley sells a bowl vent extension that will cure it.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
      Bill -
      I worked on one of these (a 3810) a couple of years ago, and it turned out to be a vacuum leak between the bottom of the main body and the top of the baseplate; the baseplate checked flat, but the bottom of the main body was warped. Had it machined, new gasket, and the whistle was gone.
      • Timothy B.
        • April 30, 1983
        • 5177
        I second what John said, get a piece of 1/4" glass cut about 3 3/4" wide and 8 or 10" long, (double check the width after you remove the base). Wrap tightly a piece of 220 wet sandpaper over it and carefully plane the bottom of the main body and top of the base. While you are at it check front and back of the main body.
        Don't sand more than necessary and don't overtighten the attaching screws including the nuts that hold the carburetor down to the intake. If you don't want to do this take John's advice and go to machine shop and have them bridgeport mill the surfaces. Also, while your at it double check the secondary metering plate surface for flat and install new gaskets there. That's what is bad about holley's, they are modular and the surfaces tend to warp over time. Don't overtighten the screws..
        One more thing, install some 7/16" plugs in the hot slot in the intake manifold just under the carburetor. That will help greatly with today's ethanol gasoline and keep the carburetor much cooler. Make sure you tape the plenum so nothing falls down by accident, don't ask me how I know.... Drive the plugs in square..
        • Clem Z.
          • January 1, 2006
          • 9427
          also make sure the carb to manifold gasket is the one that fit the manifold openings not a generic one fits all
