69 rear compartment insulation - NCRS Discussion Boards
  • Brad S.
    • July 31, 2005
    • 227
    Do 69's have insulation in the rear compartments? The JG says that in 68 after SN 9315 foil / fiberglass insulation is found in both compartments but doesn't say any anything about 69. Paragon lists it as 1968. I can't find the insulation in the AIM but in the alarm section (UA6-A3) it says to remove the jack compartment insulation to install the alarm bracket. Thanks for any help.
  • John C.
    • January 1, 2005
    • 616
    Re: 69 rear compartment insulation
    Brad
    69's should not have the insulation in the rear compartments.
    John
