(I posted this on CF but there may be more ideas here.)
The rubber "S" hose (frame to fuel pump) on my 1974 is leaking at the pump end. I did this job on a 1979 (without A/C) once and it was fairly simple. Just remember to clamp things off when working of course.
I have the stock-style replacement "S" hose and also a good length of 3/8" ID fuel injection hose if need be for backup. Keep in mind the best I can do at home is jack up the car, put jack stands in place, and remove the LF wheel. I do not have a lift. That is my working room. I use a battery-operated lamp so no electrical spark can occur.
The pump end of the hose is no problem. But I can barely see the frame rail area from above where the rubber hose attaches to the steel line. This is because of the A/C compressor and associated apparatus. Is there a trick to getting that rubber line in place? Or do I have to loosen and put aside the compressor (without removing the pressure lines)? I would very much appreciate advice.
(thumbnail)
(thumbnail)
