T-3 headlight date codes - NCRS Discussion Boards
  • Chuck G.
    • May 31, 1982
    • 2029
    Re: T-3 headlight date codes
    Originally posted by David Liukkonen (3775)
    Thanks Chuck,
    This confirms what I have found about the date codes.
    Dave
    I wish I could remember where I "pirated" that picture from. It's NOT my original work or research. I'd like to give the proper credit, if I was able.
    Chuck
      • 15573
      Chuck
      Chuck,
      I remember that as part of a larger drawing of the headlamps, but I can't remember who posted it here either.
      • Michael H.
        • January 29, 2008
        • 7477
        #18
        I "pirated" this picture/chart from someone, so I'd like to give that individual credit.
        Hope this helps the discussion.
        Chuck
        I have the rest of the print but there's not a lot of useful information on it. I can dig it out and post if necessary.
        • Steve D.
          • May 16, 2011
          • 106
          #19
          Don`t know about the dates. But to say the originals are sensitive would be a grand understatement. I would defineately only use them for judging purposes. I would also only install them at the event. This may sound paranoid. But I have run through 2 sets. I believe that alredy as stated can cause them to quit. Also dang near any vibration. I have since just settled on the repop t3s
          • Dan D.
            • November 5, 2008
            • 1323
            #20
            I do not wish to pirate this thread, but I thought I would add some 7" 1957 questions into this mix as it is a good T3 thread. If you rather I start a new post I will.
            My 57, which I have owned since 1971, has T3s that look almost identical to Lectric Limited sealed beam guide. The only difference I can see is at the top they have a 3 digit code molded it. One is;
            D-15
            TOP
            12-V
            other is;
            K-41
            TOP
            12-V
            The 3 digit code and TOP are molded into the glass. The 12-V appears to be on the inside of the glass.
            By the way, they both work, but I have not left them on for more than a few seconds.
            Is the 3 digit code a mold marking? If a date code, it does not make sense. I have not taken them out to look at the back side.
            If these have any value for judging, I can make them available, as my car will not be judged. Either way I think I will remove them and install repops, as I don't trust them. -Dan-
            • Greg T.
              • January 1, 2004
              • 136
              #21
              T3 markings by year.
              • Dan D.
                • November 5, 2008
                • 1323
                #22
                I very carefully removed both T3s from my 57 today. Rear marking at the top (stamp) is;
                G
                5400
                12V *
                4 7 2
                Both are the same. If that decodes to April 2, 1957 - that would fit as my car has a birth date of May 21, 1957, or there about. Would the * be the shift?
                Below the terminals and molded in the glass, one is;
                G-55
                TIC
                The other is;
                G-82
                TIC
                Any ideas on decoding this gobbly gook?
                -Dan-
