1954 motor mount shims - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 499
    Nolands book indicates motor mount shims to be installed on the right side only between the frame and mount bracket. Has anyone run accross this? How big and how many? Thanks as always!!
  • Guy M.
    • November 1, 1993
    • 499
    Re: 1954 motor mount shims
    FYI the shims are 1/32 inch thick and slip into place. can easily be made out of sheet metal and will need 4 or 5 on the right side only. Left side is tight.
    • Lynn L.
      1953-55 Team Leader
      • February 1, 2000
      • 162
      My 54 had 3 shims on rt motor mount to frame upper bolts.
      • Brett H.
        • January 1, 1996
        • 367
        Shims are generally always on the right side. The amount varies depending on the frame rail.
