R&R rt. front caliper & hose - NCRS Discussion Boards
  • Jeff S.
    • July 31, 1984
    • 383
    Will I need to 'bench bleed' my m/cylinder after removing/replacing the right front caliper & it's flex hose? All other connections will remain intact.
    Power brake car; original m/cyl, so no bleeder valves. I do have a Motive pressure bleeder to employ for system bleeding after the replacement ... wondering if it would be advisable or necessary to to bench bleed master. (DOT 5 fluid).
    Thanks in advance.
  • Larry M.
    • January 1, 1992
    • 2688
    Re: R&R rt. front caliper & hose
    Jeff:
    No additional bench bleeding should be necessary unless the reservoir is dry AND you have pumped the brake pedal to introduce air into the MC piston area.
    Larry
