Emerg Brake Flasher - NCRS Discussion Boards
Emerg Brake Flasher
  • James R.
    • November 18, 2008
    • 89
    Emerg Brake Flasher
    I am in need of a Tung Sol 650 flasher for my emerg brake set up in my 58 project. Can anyone point me in the right direction?
    Jim
  • Paul O.
    • August 31, 1990
    • 1716
    Re: Emerg Brake Flasher
    James
    Contact Peter Lindahl he maybe able to help you. He is a member and you can email him through the members list.
    Paul 18046
    • Kevin P.
      • November 1, 1975
      • 86
      James, the 1958 thru 60 corvette emergency flasher is a 642. the 650 is for the 1955 thru 57. Kevin #775
      • James R.
        • November 18, 2008
        • 89
        Thanks for the replies.
        Kevin, what reference are you using for that info? I did an archive search and opinions in the past were exactly opposite...the 642 was for the earlier cars and the 650 was for my car. I am only going by what I have found here in the forums...
        Jim
        • Kevin P.
          • November 1, 1975
          • 86
          James, I have sold flashers for over 20 years and it is my believe
          632-53thru54
          650-55thru57
          642-58thru60
          • John F.
            • March 23, 2008
            • 2395
            Kevin, what is correct for a 62?
            • Jim D.
              • 2882
              62 used a flasher bulb, no separate flasher like earlier cars.
              • Kevin P.
                • November 1, 1975
                • 86
                John, the 1961 and 1962 do not have a flasher they use a "GE357" bulb. only "GE' brand will flash at the correct rate, these are very hard to find. Kevin #775
                • William C.
                  • May 31, 1975
                  • 6037
                  I think you will find the number is 257 for the "blinker" bulb. (still GE)
                  Bill Clupper #618
                  • Kevin P.
                    • November 1, 1975
                    • 86
                    You are correct bill, my old age is showing. Kevin #775
                    • James R.
                      • November 18, 2008
                      • 89
                      Excellent. Thank you Kevin.
                      • Rob M.
                        NCRS IT Developer
                        • January 1, 2004
                        • 12695
                        Ask Mary Jo, she might have the flasher you are looking for...
                        Rob.
                        NCRS Software Developer
